Timing Belt Or Timing Chain?
gazza8701
Hi can anybody help me I have a 2006 toyota avensis t4 d4d could anybody tell me if it's a timing belt or chain it has? Thanks in advance.
Could be either depending on engine:
Earlier 2.0 1CD engine is a belt ( side indicators in front wing )
Later 2.0 1AD engine is a chain ( side indicators in side mirrors )
2.2 2AD engine is a chain.
Sorry I ment to say mine is the 2.2 d4d if that helps. Unsure where to look for engine codes.
it's a chain engine then
Also I have a problem with my heating In car. I have the climate control both on (Hi) if I don't have the fan on full it looks like the car is going to overheat, then I put the fan on full and the temperature gage drops back to normal in the middle and I get hot air for about a minute then it goes back cold. Does anybody know what the issue could be? Thanks in advance
how is your coolant level?
?Done any work or changed the coolant recently if so you could have an air lock in the system,if not i would look at changing the Thermostat. :D
