Headlight Unit
Phil F
I need to get a new near side lamp unit and the local Mr T has quoted the princely sum of approx £250,wow!......could anyone recommend a cheaper option please?
Cheers....Phil
New aftermarket headlight units are available on eBay for £60 ish.
Thanks Gazza,
Has anybody here actually bought any of these aftermarket units please?After doing a bit of research some say the quality/fitting can be an issue?
Also I have seen a couple of YouTube vids describing how to fit the unit,it seems fairly straightforward?...famous last words!
Thanks all
personally I would buy a used headlight from a breakers or eBay rather than a copy. would rather not have the hassle of not lining up
if buying used make your all mounting brackets are intact.
what year is your avensis 2003-2006 are slightly different to 2006+
I've gotta say I agree and I'd always go to a breakers or genuine new / secondhand rather than a copy. A lot of pattern parts are good copies but Its rare to find an exact copy :)
Hope that helps :)
Thanks Drew,
Funnily enough the service advisor at my local Mr T. said the same thing about the pattern parts,but £250 is a bit prohibitive.
Phil
reflectors for headlights bulbs are prone to lose their chrome and emit poor light beam so I personally wouldn't get a second hand unit.
if I mind right there is a service for sending lights away to get opened up and this reflector replaced or plastic rechromed
this is info off top of my head
anybody know of this or a link about it?
as my headlights are a bit garbage in the dark
might be time to get this done
