Links And Images. Possible Forum Problem With W8.1 And Ie11
Mooly
I have encountered an issue with the forum freezing when the following boxes are open. It seems to occur under W8.1 and IE11. The only way to exit is to either close the tab or use task manager to close IE. The "Message from webpage" box is responsive but the open forum box will not close using any of the three options, X (close) OK or cancel.
Tried the same things using Vista and IE9 and all works as expected.
post-57576-0-68034800-1423407942_thumb.p
post-57576-0-96517000-1423407952_thumb.p
Click the Cog icon and use the site in Compatibility View mode... Let us know if that helps!
