Yaris 2012 Front Tyre Outside Edge Nearly Bald
Si yaris
took my yaris to have wheel alignment done at local toyota garage again as it was done with service a couple of months ago and again it showed that it was within the limits anybody getting bad outside tyre wear the pressure is correct and all they could say was they could put a new tyre on for me whats the good if its only going to last 6000 miles does anyone know if it can be adjusted on leg or if it fixed help please never going back to toyota again service plan dumped
I had a similar issue with my Mk1 D4D; I found boosting the front tyre pressures a bit helped make it wear more evenly, but you may need to experiment a bit as it will vary a bit depending on the tyres and driving style.
Welcome to Toyota Owners Club.
A bit more information wouldn't go amiss. From the original post, you mention having a new tyre - so is it just one front tyre that is showing heavy wear (and if so which side), or both front tyres?
just the nearside they offered to put a new tyre on at normal price offside is wearing ok they said that their £12000 set up couldn't be wrong and that alignment was ok
I'd get a specialist alignment done. Not sure that the best equipment will work if set up by someone who doesn't know what they are at! BTW, did they give a print-out of the settings, front/rear, before and after alignment?
given a printout at service and also today not much difference in the results front or rear someone did say that might not be adjustable but can't find out
whats the difference between the 2 tyres? also n/s/f normally wear very slightly quicker than o/s/f
Alex
tyre could probably do another 6000 miles if it wasnt for outside edge being bald o/s tyre wearing evenly pressures correct
