is there a particular method for bleeding the injector pump on a 2002 corolla 2.0L D4D (1cd ftv).
The car wont start so I took out one of the new scv valves I had fitted and very little fuel run out. I'm thinking the pump might need bled.
Thank you in advance
Hi mate, I not familiar with your car but sometimes these pumps have a solenoid cut off valve. Get a mate to turn the ignition on and off a few times while you touch the valve and if its working you will feel or hear it click on and off!??
should handprime at fuel filter with ignition on
should start after a few turns
bigger problems or a bad filter seal drawing air or similar
