Engine Change - Need Help Please
huggy near
hi their i have my self a 2006 1.6 vvti avensis with the engaine after giving up on me
im need to know will a 1.8 vvti engaine work in the car ????????
thanks for any help please
It should work but the ECU may have slightly different parameters.
Check the following link -http://www.japan-parts.eu/
You can compare part numbers and other differences between the two engines. The exhaust system may have a different down pipe, due to the engine height, but again part numbers will tell you.
Good luck.
