Thought it was bulb on passenger side rear. classic front and side double blinking,and rear not working.
Turns out that bulb is good,but swapped out anyway.
All other bulbs good,fuses checked and work fine when hazard switch used{single blink,but rear one still not functioning}
Is this a relay,wiring or stalk prob?
Any help appreciated
This could just be a bad earth connection at the bulb holder as you say the bulb is good.Is it a snug fit in the socket ?
Can you check if power is reaching the socket as this will be a start point ?
Del
Thanks Del,I'ii check now
Sadly,the bulb is snug and no poz to bulb,either on indicate or hazard.[verified my tester with the side light bulb,so problem not at the back]
What else please? Just typical when MOT due shortly.
Thank you for trying to help me
Did you test for power and earth on the socket or an earth on the body as well and what type of bulb is fitted,are they bayonet cap or capless
Del
Earthed down to light unit and double checked with a good earth on the car itself.They are Bayonet fitments.
As you have checked the sockets and fuses then it may be time to check the connections/plugs on the between them
thanks for your help,I,ll sort it somehow
rgds John
take the hazard light switch out and make a note of the wiring colours for you indicators then using a multimeter you can check from one end of the wiring to the other for continuity at least you can rule out any breaks in the wiring,just one other thought have you had the teabag effect where water pours in from anywhere on the rear end as you may have a corroded connection on the multi plug
