Avensis Fob
patcaff
Just bought a 2005 Avensis Estate Spirit very pleased with it but it came with only one key, I've sourced a blank fob but without the module, can someone point where I might source one and programme instructions. I don't think my car has an immobiliser fitted but how would I know?
The existing key is a Valeo.
Any help from a newbie would be appreciated.
Regards
You need an old key (you can supply it from anywhere, as long as it's a Valeo, same as yours), and new blank. Cut the blank after your key at a local locksmith. Fit the electronics inside. Program the key (the immobiliser and the remote control for the doors). There are how to's on the forum. Use search function.
LittleM@n
Thank you for your reply, I will continue my search to include scrap yards there are one or two around Torbay.
Re the immobiIiser were all Avensis fitted with one?? I did take my supplied/existing Fob apart ( to check the battery) but I didn't see anything obviously looking like a chip embedded in the plastic which is where I assume it would be.
Many Thanks
