Unable To Put Rav 4 Into Gear On Startup
royslade
Hi was wondering if anyone here can help have been having this trouble changing gears for a while now with my Rav 4 it started when having troule getting it into 2nd whilst moving but it seems to be getting steadilly worse when now I have trouble getting the car into gear on startup.If left in gear when started it stalls instantly even with clutch fully depressed. Any help will be much appreciated thanks in advance. Roy
Clutch failure. Or broken flywheel..
Have had this car for around 18 month bought from my local dealership is it possible that a sheared off timing bolt may have caused this to happen as a short while after purchasing vehical my car had to have half an engine replaced due to this happening whilst my car was still under warranty. If this isn't the case as I'm not mechanically minded can anyone tell me how much it would be to repair. Thanks Roy
This could be a failing clutch slave cylinder, check to see if the brake/clutch fluid level has dropped and locate the slave cylinder attatched to the gearbox and check for signs of fluid leaking.
Not mechanically minded I'm afraid wouldn't know where to look for those things sorry.☺️
