Difficulty Installing Front Wheel Arch Liners
BeddyLad
I've got a used 2005 avensis which I hadn't realised didn't have front wheel arch liners.
I've got some and looked forward to fitting them when I found a potential problem.
At the front where the liner angles under the front wing there is a row of 4 holes but nothing to attach them to.
Can anyone tell me if there is supposed to be a bracket there from the wing to the engine?
Thanks in advance.
Sounds like there's some bits missing. I can't remember exactly but there are a few different pieces around there which all screw together.
this should help
I believe they are plastic rivet clips- part number 90467-10183 they are available on eBay, not cheap for Mr T.
Thanks for the schematic. The area I'm having trouble with is where numbers 5 and 6 are on the diagram. There is nothing currently within the bodywork for the plastic rivets to attach to.
I have a good supply of those rivets already :).
Do you have a schematic of the bodywork internal and external of the front wheel arch?
Thanks In advance.
b22049_spinka_mocowania_nadkola_zderzaka
these(90467-05138) hold the bottom lip to the under trays once lined up 10mm (90159-60488) bolt goes through these to secure.
above is 4 and 5 covered.
6 is plastic rivet clips with a different part number maybe different size hole to 3.
