Is This The Camshaft Sensor
RichT180
Trying to fit a Lindop chip kit to my 60 plate Avensis, Following the instructions I'm sure this is the right one as shown in the attached pictures. The problem is the plug on the car is 2 pin and the one on the kit is 3 pin? Any advice pleasepost-120863-0-57355200-1425059893_thumb.post-120863-0-36491100-1425059924_thumb.post-120863-0-22922400-1425059965_thumb.
Just to follow the first pic shows the plug on the car, second is the plug on the kit and the third is the position under the bonnet back left of engine. Its a 2 L d4d
Did you get this sorted Rich? if so how does it perform?
I know that bluespark do both 4 & 6 pin connector versions of their chip for the 2.2 depending on the age of the vehicle - perhaps the 2.0D is the same?
Did you buy the chip direct from Lindop or s/h?
Got it direct from Lindop, Kingo is on holiday till next week so got to wait until then, the booster plug on the car is 2 pin and 3 pin on the kit
Camshaft plug not booster
