Auris Hybrid 60 Plate, Engine Feels Like It Will Stall
SunilK
Hi All
I have a Toyota Auris Hybrid, 60 plate. Drives nice, MPG is ok, around 45-50 MPG. Nearly 75K miles on the clock. No issues until recently.
Got an intermittent issue, when stationary, engine vibrates & the car shakes as if it will stall. Anyone else had this issue?
The dealer had the car for a few days, & the issue did not occur, & they undertook a full hybrid health check & no issues came up.
Any ideas?
condensation on the inside of the inlet manifold would be my first guess
Alex
  • 2 years later...
If that is the cause, how do you rectify/stop it???
I had the start of the symptoms you describe. I had a failing coil, number 1 coil. water had ruined the coil, it looked a right mess, rusty, the bottom rubber boot was loose and the spring inside the rubber boot that makes contact with the spark plug was very rusty. everything was wet. When I managed to get a tool to remove the spark plugs, the plug was rusty too.
After replacing the plugs and the damaged coil my car is running perfect again.
Here you go  4-TOYOTA-VERSO-PRIUS-1-8-VALVEMATIC-VVTI-PETROL-COIL-PACK-X1-2009-2016-/302167966618?hash=item465a9d439a:g:LegAAOSwJ7RYU-Es
and plugs  http://www.ebay.co.uk/itm/4x-DENSO-IXEH22TT-IRIDIUM-TT-SPARK-PLUGS-FOR-TOYOTA-PRIUS-1-8-Hybrid-04-09-/152476769923?hash=item238052de83:g:Yf4AAOSwhQhYzUdD
