What Are The Largest Wheels For An Auris
Jag XFS
Hi what is the largest wheel size for an Auris I would like to upgrade my standard wheels any recommendations would be appreciated I need to fill those wheel arches as standard wheels look a bit lost :D
I think The biggest anyone has gone so far is 19 inches .... Depending how low profile you can get your hands on you could possibly fit a set of 20s but the ride would be ruined it wouldn't handle proppely and one pot hole or one bump and I reckon that would be a very quickly become a bad day as there is a high risk of buckling of cracking a rim and of course blowing a tyre out
Do you mean big like big or fat?
Fattest:
Front 18x8,75 ET 35, 215x35x18. Rear 18x9,75 ET 20, 225x35x18.
Biggest:
Size is not confirmed but looks like 20"
19x8.5, 225/35/19.
I know that with 8" wide wheels you can use rear offset around 30 and front around 40 if your tyres are not stretched. You can use this as a base and count the correct offset for the size you want.
18s look really good I am now going to do a bit of wheel shopping thanks for your advice Guys :D
No problem! Good luck and post back when you've bought them. 18s are more than enough, especially if you'll choose some model without the lip. Lip makes them always look a bit smaller.
  • 2 months later...
what concave type\model is that wheel called on the orange auris that looks so nice
XXR 527, they indeed look nice :)
  • 5 years later...
Hey,
I understand most of the dimensions etc but what is '75' for?
example '18x8,75 ET 35'
Is it the same as 8.75 ?
18 - diameter
8,75 - width
ET 35 - offset
Width can also be shown as '8.75'. Measurements in inches.
