Cam Sensor
toppo123
hi, could anybody tell me which cam the vvt sensor reads (the inlet or outlet cams) trying to find the problem with cam and crank not in sync,it is a 2008 yaris 1.3 petrol with 29000 miles, would a timing chain stretch so quick with 29000 miles on it,thanks
If it has been serviced properly,you should have no issues.
Properly for a low mileage car is annual oil and filter changes to the correct specification.
Old oil in a car used for short journeys will wear chains rapidly.. especially from cold as the chain will be starved of oil when the engine starts turning..
A worn chain rattles - especially when starting from cold...Does yours?
thanks Madasafish but it had it serviced every year with new filters & oil,there are no rattles from the chain,would the vvt sensor cause this problem
