Rav4 Radio Aerial Connection
BJB
Need to change my factory fit radio with a newer Toyota radio but the aerial connection in the new radio is different.
The old radio has a round socket to take a standard male aerial plug. (see picture one) post-73339-0-75655100-1426781433_thumb.j
The newer radio has a rectangular socket to take a rectangular male plug (picture 2) post-73339-0-26471500-1426781450_thumb.j
Anyone any idea if there is a simple connector available to make the job simple?
Bryan
What audio unit did you buy, the connector looks like the new amplified antenna type used on current models?
It's a Panasonic 53831 ref 86120 - 42280. Yes from a recent Rav4 when the previous owner changed the unit for a dvd / sat nav model.
Single cd model. I had a 6 cd model and wanted to fit a Connects2 unit using the cd socket. The Connects2 system does not work with the 6 cd changer unit.
Bryan
Part number PZ457-00260-00 from your local Toyota dealer should convert from the earlier round plug to the later square plug
Lee
Thank you very much for your help. Much appreciated.
Bryan
