Wanted, Original Tein Coilover...
barryp
well lad's and ladies, its my first post and first time here.. how are ye all? as the post suggest's im looking for a replacement celica 190 front passenger's coilover, actually i just need the shock, the spring seem's to be in good nick... i think some of them came with these as standard but im open to correction. any help or if ya know where i could get 1 would be great.. cheer's in advance :D
Celicas never came with teins as stock, you can get TTE springs from the dealer, but that's about as much as you'll find coming from the factory.
If the coilover is green then it is a tein shock, also good luck in finding just one, what exactly is the problem???
if it's damaged you'll need to send it back to tein uk who can sort it out for you, otherwise you'll be fitting a new or used set of four. If they are damaged most either chuck them out or get them repaired as you can't really sell a set of two or three.
cheer's for the reply colin... they must have been just made especially for my the celica then because me one has the start of the chassis code on it, my mistake. the shock is leaking a decent bit its not bent or damaged so hopefully tein can repair it for me...
If you get in touch with tin UK you can send them back and they repair them.
http://www.tein.co.uk/contact_info.html
Previous owner must have fitted them, it will have the start of the chassis code because most aftermarket car parts are listed by manufacturer, then model and chassis code.
It will have ZZT23 on it as they fit the zzt230 which is a 140 and zzt231 which is a 190/t-sport
i was in touch with tein earlier, sent them on part numbers and everything so im just waiting on a reply from them now, cheer's man, your a life(and wallet) saver..
