Mk1 Rav4 Replacement Door Lock
jetdavex
The passenger door lock on my 1995 3 door RAV4 is worn out - the key won't turn. My mechanic tells me that replacement barrels are sold which can be adjusted to fit my key. Does anyone know where these can be sourced, or if barrels from another elderly Toyota will fit, or if generic parts are available? I believe the part number is SIDL111R or DL-111R. Thanks.
Hi David, do you have another key that you can try as it maybe the fault is not with the lock but a worn key
Del
Thanks - I've tried both keys but of course they may both be worn!
