Low Ilde And Stalling After Fitting A New Battery!
bonjo
I decided to give the 12.5 yo Battery a break and fit a new one.
New one fitted yesterday. Engine starting etc. All went well until today when I drone the car.
Once the engine warmed up the idle speed had dropped to 200~300 rpm almost to the point of stalling.
I don't think I accidentally disconnected or knocked anything off.
All I did was to remove the trim cover on the the top of the Battery. Disconnect the - the + terminals and connect them to a stand by Battery (so as not to loose my radio presets). Fitted the new battery, reconnected the cables and finally cranked the engine to ensure it would start.
SO I am confused as to what I did or what I didn't do!
Any help would be appreciated
As soon as I saw this I knew it was a petrol. Yes it does this for a day or two. Coming up to a junction can be a nightmare without blipping the throttle. The ecu relearns what to do after a bit of running. It's normal.
indeed you are right.
thanks for the info. Comforting. I will soldier on till all settles.
Wonder what they do at the garage when they change or disconnect the Battery without affecting the idle :bookworm:
UPDATE
Thankfully as pmb mentioned the idle is back to normal after a few days and 80 miles down the line
