Drop Link Advice
mikey-t
Hey all, Gonna be replacing the front drop links on the T25 soon.Just wondered which make is a good choice from the thousands of manufactures on eBay? Also are there any hidden pitfalls i need to look out for when fitting? cheers all.
Try Toyota parts if its only little difference go for the genuine or try www.eurocarparts.com using promo code tweet5
Could also try some poly ones (e.g. from superflex or energy suspension), but they can be pricey.
Fitted delphi droplinks to mine 2ish years ago when i lowered car.
These have been fine
Pitfalls
I ended up cutting off old nuts as the usual everything just spinned and never slackened off
Pitfalls
Cheers guys. Rob, am i right in thinking i just just have to jack the car up? For some reason i have a thought in my head that i have to stick a jack under the lower wishbone to take the tension out of the A.R.B and droplinks too?
Pitfalls
I just stick a long bar through the wishbone to lever it whatever way it needs .
jack may be handy though
