Clutch Making A Whining Noise When Pressed Down...
lestermester
Hi
I've got an Aversis Verso 02 reg.
When depressing the clutch to change gear, the clutch is making a whining noise.
I only get the sound when depressing the clutch.
Does anyone know what this could be?
A Faulty Clutch release bearing would be the most culprit
Expensive fix? Any idea?
well the gearbox has to come out to replace.
Like has already been said the gearbox has to be removed, i highly suggest you have all 3 parts of the clutch replaced and not just the clutch release bearing, so basically just get the price of a replacement clutch.
Good luck, Mike.
  • Like 3
When was you clutch last done anyway?
BTW it's not uncommon for a clutch to continue working for years with a noisy bearing, but similarly it might not.
i dont think i've ever changed the clutch or done anything to it. Car has done maybe 120k miles. thanks.
Clutch kit replaced. All ok now.
