1Cd-Ftv Problems, Getting Desperate
Jeikob
Hi
My 2.0litre D4D rav4 is giving me a headache. Car is losing power around 2500-3800rpms. Works good on other rpms. Done so far:
- SCV valves replaced
- turbo replaced (was faulty, thought that was the problem but no...)
- MAF cleaned (temps still quite high, what are normal values?)
- Fuel filter changed twice
- EGR cleaned, seems to work
- No fault codes or engine light on, checked on Toyota dealer (and no other faults according to computer)
- Washed intercooler & tubes, no leaks
Help please :)
  • 1 year later...
Same problems With my car ....did you solve it?
  • 5 years later...
I experienced a similar problem with my RAV 4 D4D 1CD FTV 2003 model. I replaced the Common Rail Pressure Sensor and it solved the problem. Figured it is usually the biggest culprit when it comes to that problem.
