Sd Card
Adam Evans
My IQ didnt come with the SD card
Is there any way of making the maps work without an original card.
Can I download an image from the internet for this ?
Adam
No Adam you cant. The map data on SD card is encrypted using the original card manufactuers serial number.
Things you can do are make a SD card with the tns510/350 operating system on it so your radio, bluetooth etc will work but no map data
David
Brilliant - at least I can keep it working !!
I have done some digging and some crazy Russians have figured out that the CID code on the SD card needs to match the code inside the compact.wdt file
But that's as far as they have got
I have managed to find a link to pz445-sd333-10 on the internet and now have a full image but have no way of reading the compact.wdt file to find out whats in it
The CID code is different for each card and us used to encrypt te datea as its put on each card
David
