Avensis Verso 2003 Diesel Front Disc Backplates/dustplates
JohnnyBoyxxx
Hi all, my Avensis Verso 2003 Diesel recently failed the test due to corroded front disc backplates/dustplates, NS and OS.
I am having a lot of difficulty sourcing used or new replacements.
There are plenty of breakers yards that have them but i assume it's too much effort to remove wheel, calliper and discs to get to the parts i need.
Can anyone here point me in the right direction?
Also, does anyone know if the front discs on the Avensis car the same as the Avensis Verso MPV.
Kind regards
John
wierd mot fail
Is it a case of remove them completely and it cant fail for this again.
Then gives you time to source the parts.
I agree with the above
I doubt you will be able to get these parts in the aftermarket world.
try your local Toyota parts or Parts king on here.
http://www.toyotaownersclub.com/forums/user/34014-parts-king/
the part number for avensis ones are
LH-47782-05030 RH-47781-05030
My apologies for an incorrect question. My car failed for 2 'CORRODED' brake pipes to rear brakes and 'MISSING' not 'CORRODED' as i originally stipulated, front disc backplates/dustplates, NS and OS.
Not sure how they became missing as it past the last test without issues and hasn't had any work to the front since.
Thx Avensis4d786 for the links and part no's.
Are you sure its the same for the Verso?
No I am not sure if they are the same i just gave you the part numbers for reference.
No they are not the same as an Avensis
Avensis Verso:
RH 47781-28200
LH 47782-28200
