Fuel Pump Relay Switch On Carina E 1.8
Hi, can anybody tell me where to locate the fuel pump relay switch. I've had to bypass it in order to get rid of the infamous misfire, not ideal, I know, but without knowing where it is I cant replace it.
I'd say it's probably in the fuse box under the bonnet. The one with the EFI Relay in it. As looking at the Haynes manual , the relay for the fuel pump is wired from the EFI relay.
Are you sure that's the problem though ? Always seems to be a failing injector that problem. I've had a few go myself !
Sent from my iPhone using Toyota OC
