Will Vw/seat Wheels Fit?
bigbobsbastardbeans
Evening all, been given a set of 18in alloys from a seat Leon and was told they would fit my avensis 08 hatchback??
Any one if this is true and would I need to buy new bolts/nuts to fit them??
Many Thanks
Si
Moved to the Avensis club
VAG/Seat generally are 5 x112 PCD but I think yours are 110? (mine are 114.2 x 18) but if they do fit on check the offset,plenty of wheel size comparison sites to check for correct ones for yours and alternative sizes.Tire Size Calculator | Compare tires and wheels is just one. New bolts and or different seats may also be needed for VAG group wheels.
if your car is a 2.2 then wheel PCD is 5x114.3 with a bore of 60.1. All the others are 5x100 with a bore of 54.1.
Nuts are 1.50 & offset 45 for all.
How old is the Leon? http://www.wheelfitment.eu/car/Seat.html
step1
take a wheel off your car
step 2
try to fit one of the wheels you've been given
honestly its the only way to see if they look ok ,before buying all the hub spacers and anything else that may be needed
step1
step 2
Haha well said,you can think n wonder and compare PCD radiuses and dwell on each set of wheels offset or........
Take off a wheel and see if it fits, maybe the offset will be different but you'll find out if that's a problem if the wheel actually fits.
You can over think these things sometimes lol
