I Need Help Rav4 2.2 D4D 2007 Egr Valve
onthegow
I can find reference to plenty of folk saying "clean the EGR valve" to solve your problems and "wow! what a difference" afterwards.
But is there a guide to doing it or pictures of at least where it is (2007 2.2 D4D engine)
what to use to clean the soot off also would be handy
thanks in advance, oh and I am new tot he forum
Hello Will - welcome to Toyota Owners Club.
Thread moved to the Rav 4 club.
Hi Will And welcome.
If you scroll to the top of the page to technical info then scroll down down that page to the 4.3 section you will find help there
Del
hi Del
I may being a little thick here but I don't seem to be able to locate the technical info at the top of the screen... there is no technical info TAB that I can see anyway..
Will
Go onto the main rav4 page and it will be just above this post if you are still online
Hth
Del
Hi Will.
Carburettor cleaner is a good product to clear your EGR valve, it is just a spirit that cleans off carbon, gunge and stuff. There's lots of 'nasties' that come out of the valve when you clean it so get it off your hands as soon as you can.
If you go on You Tube and put in 'cleaning Toyota 2.2 EGR valve' there are many home made video's on how to do it.
Regards Mike.
Hi I have been absent from this forum for many months (working away) just to remind you Rav4 2.2 owners why don't you try blanking off the EGR valve, no more cleaning and runs better, I heard all the storys about why you should not, but I served my time as a fule injection engineer for CAV, so don't go there, just try it, if you don't like the results like less smoke etc, etc,etc, revert back, plenty of posts to search for to find out how to do it....
how do all.
I have cleaned this up now so finger crossed no more fault codes.........
incidentally does anyone know the run out for front brake discs for rav d4d. changed the brakes last june and now there is a judder.
thanks for all your help everyone
Hi everyone.
I have cleaned the valve cleared the codes and it is running good onto the next jobs....
