Hey guys, Hows things going?
Couple of quick questions.
Central Locking Problem - When I put the door key in to unlock (two seperate keys, one for doors and one for ignition) all of the doors unlock apart from the passenger side door? Any theories?
Electric Sunroof Problem - (bear in mind, I havent checked inside the light to see if the cables are attached (they removed the back window cables to install a satnav system, maybe they did the same with the sunroof?) but basically nothing works when i press the buttons. #
Thanks for the help.
Josh
