2014 Rav4 Dashboard Lights
Davenlois
Are these dimmable? If so where be the 'knob'. 2014 Invincible 2015 plate.
Should be a button on your instrument cluster which operates as the 'instrument cluster light control' (not the odo/trip button).
With the sidelights on, press and hold the button for more than 1 second, and the brightness of the instrument cluster lighting will adjust.
Thanks for the reply. It turns out it is the ODO button. Lights on and use the button to scroll through and then set the brightness. Simples!!! when someone tells you how! :clap:
