2007 Rav 4 D-Cat T180 Brakes Disc Run Out
onthegow
Hi all
Has anyone any ideas or technical info on brakes run out for the from brakes for D-Cat T180 Rav 4.
I replaced the front discs last year and just measured the run out due to brake judder.
i measured the run out either side of the vented disc and did not get any two reading the same.
passenger outside of the disk was 4 thousants if an inch
the inside of the disc as 1 thousands of an inch
the drivers side disk
outside of the disk as 6 thousands of an inch
the inside of the disc was 5 thousands of an inch.
not knowing the lateral run out specifications i would say that perhaps the riverside disc is way out and causing the judder.
any suggestions.
cheers
Will
Fronts
Maximum disc run out 0.05 mm (0.0020 in.)
Rears
Maximum disc run out 0.15 mm (0.0059 in.)
