Sr180 Alloys Spec
tomosllyr
I have searched, but havent found a straight answer. Can someone confirm that the SR180 alloys are 17*7"? And et50? I might be sourcing replacements.
5 spoke ones where the centre of the spoke is indented? Mine are definitely 17...
Alloy specs for all Auris 2007 onwards are the following:
- 7J x 17", ET+39, ET+45 or ET+50 , PCD: 5 x 114.3 , center hole diameter 60.1 mm;
- 7.5J x 18", ET+39 or ET+45 , same PCD and center hole diameter.
Isn't there 16 inch Auris rims on the lower spec models
Actually I've just measured and they are 18". I assumed they were 17" because of the tyre size.
The first generation Auris came with either 15, 16 or 17 inch wheels as OE, depending on spec, with the most common fitment being 16's.
For example with the pre-facelift first generation: 15 inch steel wheels were fitted to the T2 base model: 16 inch alloys were fitted to the TR, and T-Spirit; 17 inch alloys were fitted to the T/SR180
Info taken from the 2009 brochure and the Toyota excel spreadsheet on tyre sizes.
2008 57 plate UK Auris SR180 definitely only has 17" wheels with 225 x 45 tyres. Im almost certain that fitting 225 x 40 x 18"'s on this car will result in rubbing on the inner arches....
