Driveshaft/hub Nut Size Mk1 2000 Avensis
Edwardius
Hi all,
quick question, what size nut is on the driveshaft of a pre-facelift 2000 avensis?
I think it is 32mm deep socket. I am not home but sure it is. Got one in my tool kit.
Will confirm when I get home later.
Update.
It is 30mm deep socket.
post-76861-0-43357400-1429224254_thumb.j
I have had it for well over 20 plus years and I used it on other cars.
I have confused myself as I have two other sockets that fits, plus the wheel bearing kits come with nuts of either 30 or 32 mm.
post-76861-0-27895500-1429227069_thumb.jpost-76861-0-99325800-1429227470_thumb.jpost-76861-0-25187800-1429227479_thumb.j
The bolt is easy to access and measure.
I will check later which of the three sockets fit.
