Drive Belt Tension Power Steering & A/c Compressor.
DOG7
Hi, does anyone know how to adjust the tension on the v-belt that drives the power steering & a/c compressor it t3-x d4d 2.0 2005. Had a look this morning and it seems to be slack, you can turn 180o degrees ?, I think it should be 90o. Symptoms are in a morning when I leave home it nudges a little on full lock. Thanks.
Sent from my iPad using Toyota OC
Hi, avensisd4d786.
Thanks for PDFs it's easy when you see these schematics diagrams, thanks again your a top man.
you can download the whole manual from the internet just look for avensis workshop manual.
Hi, avensisd4d786. Found an PDFs on line just downloaded them also , adjusted my v-belt , happy days. Thanks again.
