Anyone know the torque setting as I'm changing driveshaft cheers
For the standard rollas 2002/2006 1.4 /1.6 its 159 ft /lbs, ( Haynes manual ) , though no idea if your TS is more or less ?
That's the figure I've seen about, I assume ts will be similar if not the same, thanks for that
