3Sge 3. Gen. Tuning Help Needed
TARManiAC
Hi
I´m about to do a complete overhaul on my 3.gen. 3sge, and while I´m at it I´ve decided to have some fun with the engine. I´m getting customized 264* cams, Fidanza flywheel, cai to oe airbox, free flow exhaust + some other bits. I have a friend who will mill the head but I´m not sure how much to take off. I read somewhere once that 1 mm would be ok. My main concerns are:
1 detonation
2 will the oe green injectors deliver enough fuel for this setup (circa 220 hp)? or do I...
3 ... get an adjustable fpr og high flow fuelpump?
4 is it correct that this engine doesn´t have a knock sensor?
Oh, and I already got St205 brakes and a s54-06d gearbox for my car :clap:
Any other 3sge tuning info welcome :cheers:
FYI 3sgte or Beams are no options in my country unfortunately.
  • 2 months later...
Got the head milled, cams are reground to circa 270* according to the maschineshop and I´ve checked for valve clearance. All seems good. Started to do some mild porting on the head too. After advice from Hurley Racing I´ve decided on an adjustable FPR.
I need a Fidanza flywheel and Magnecor leads. Anyone who can reccomend a shop that sells both?
What a lot of support!! NOT
This isn't the type of club where owners spend a lot of time and money on modifications.
For that kind of club, try celica-club.co.uk
How come I get a naughty boy warning point for the very mention of "that" club.? :dontgetit:
Neil
Well, Neil..the moderators on here, are stricter than "that" other club. They would be keen to ensure T.O.C. is not being used to promote other forums, and rightly so, IMO :)
:laughing: ..by 'eck...you must have a few warning points then :g: ;)
Neil
  • 4 months later...
  • 4 years later...
How did this go in the end? Thinking of doing a similar thing, cheers
The OP last visited the club in December 2015, so you may not receive a reply.
