Wheels Not Spinning Freely
dexgotabigone
Hi ive just changed my front brake discs and pads but on the drivers side wheel it does not spin freely it will spin for half a turn and then it will go hard and rub on the pad hard what do you think it could be? thanks
Sounds like your disc may not be sitting flat enough on the hub, take it off make sure to give it a good scrub with a wire brush and re fit, never put any kind of copper grease or anything else between the disc and hub as it can make the disc not sit flat, and sometimes just moving the disc around a wheel stud or two can eliminate the problem.
Hi yes i removed the disc and turned it 180 degrees put it back on and BAM was spinning freely! Unbelievable! thanks for your advice
