Cruise Control
im_ka
Hi,My Rav4 2006 doesnt work cruise control option.When I switch light on panel appear but not actions.Cant to change speed and more else, only switch on and off.What could be possible reason Or maybe some could explain how does it work?Many thanks.
try the switch on the clucth pedal, this is not a common fault but I have change one fairly recently, the chap had exactly the same problem....
Hi,I checked its working,because I have key less start.Maybe need check brakes switch too ,it also switch of system.Very interesting that I dont see choosen speed only cruise control light on and off.
