Wanted: Celica Alloys
vicious77
I am after a set of original 6 spoke alloys for my 2004 celica.
Can anyone help?
Moved to Wanted section
Hi, James. Would you consider a set of 17" after-market wheels?, as mine will be coming off the car this week. The rims are unmarked, and the 205/45 tyres still have around 5-6mm of tread. Spigot rings and wheel nuts are included, and I can even fit them for you if required. I'm just over the border from you in Notts.
Hi, Thanks for the reply.
Can you send a description of the wheels and is it a set of 4 or 5 (including spare) ?
OK. The spec. of the rims are as follows:
17" x 7JJ, with an ET/Offset of 35. As the ET/Offset of a 17" Toyota rim is 38, these sit 3mm outboard of the standard rims. They're fitted with 2 x Falken Ziex ZE912, with 5-6mm of tread. The other two tyres are Kumho LE Sport, with 6-7mm..so very little wear. As mentioned above, these are the correct size for the Gen 7.
I was looking for £400 for them, but would accept no less than £350. I'm sure when you click on the link below, you'll know whether you like them or not.
https://www.google.co.uk/search?q=wolfrace+shark+alloy+wheels&biw=1600&bih=740&tbm=isch&tbo=u&source=univ&
sa=X&ei=QrtEVPzrJsHY7AaCyoCYCQ&ved=0CGEQsAQ#facrc=_&imgrc=_JXIsgPuVttgEM%253A%3BlWlfqd2cvlioBM%3Bhttp%253A%252F%252Fi01.i.aliimg.com%252Fphoto%252Fv0%252F112197373%252FWolfrace_Shark.jpg%3Bhttp%253A%252F%252Fro115949905.fm.alibaba.com%252Fproduct%252F112197373-0%252FWolfrace_Shark.html%3B400%3B405
HTH :)
