Fitted A Blitz Sonic Air Cone Now The Engine Malfunction Has Come On&#
I recently fitted a second hand Blitz Sonic Air Cone onto my 2004 Corolla 1.8 Tsport.
It was working fine for the first day but then the engine light came the day after. The car feels no different in it performance but I was advised if it was to do with the replacement of the filter the light would have came on straight away. Is this true?
Has anyone had the same issue and if so is there a easy fix I could try or should I get a diagnostic done?
Cheers,
Luke.
Try refitting the old one, get a device to cancel the code or even leve the negative of the Battery disconnected for 30 mins, reconect and see if the light goes out, then this will answer all your questions............why did you fit an air cone anyway, just curious.
Mike.
Thanks will try these. I got the cone free when I purchased the car, so I fitted it.
Hi Luke.
The fact the cone come free with the car suggests maybe the previous owner fitted it and had problems hence why he took it off again, just a thought?
Regards Mike.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
