Hello ive got a Toyota aygo sport 2006 and have got the original sound system still in but the left hand side Speakers in the front and back seem to not work, I set it up so all four Speakers are working and its perfectly fine then ill turn my car off and then go out somewhere the settings will still be the same but the left hand Speakers don't work. is there anything I can do and how much will it cost?
Not actually played with the stereo yet.
Most basic stereos will only allow you to fade out the front or rear (e.g, if you had a sleeping baby in the rear or kids were in the back and wanted to listen to music and the front passengers didn't want too). You will also have the option of having the left or right side on...but in truth I've only ever used that when checking if Speakers were working properly.
So allowing for the fact that yours plays on all then plays on one side indicates a fault, as I am sure they car won't have an audio memory of any type (that alters the sound stage dependant on which key is being used). So if you have the know-how you can test the impedance of the wiring, if not pay a local vehicle electrical specialist to diagnose and fix for you....it may only cost £30 or so...could be something as simple as a loose connection in the back of the head unit.
im heading to yorkshire next week to pick ap a load of panels for a restoration project im doing for somebody so if u are near barnsley area ill have a quick look for you
