Thought I'd share my Corolla track car build,
It's an 02 t sport done 99k wasn't in too bad Nick but needed quite a bit of tlc,
So far it's had quite a lot of weight out circa 140kg,
Coilovers, changed all calipers with better condition ones, fitted braided lines new discs and yellow stuff pads all round with it 5.1 fluid. Mishimoto Rad as old one was leaking
In the middle of getting the wheels refurbed, cars had a full service, just lift bolts to do, gearbox oil change, then she will be ready to blast round :)
One knackered wishbone replaced, also fitted smaller Battery up front and made a bracket to secure it, a couple of kg saved,
Some pics
Wishbone bush
And Battery
Lift bolts changed, these wear and do snap occasionally, good to see someone has previously looked after the car as it had the newer revision ones fitted, they were showing signs of wear, the shiny rings on the bottom. One more less thing to worry about :)
Looking nice.
How did you pull 150Kg out of it?? That's quite a bit!
Looking nice.
Lots of stuff out got a breakdown by kg if your interested lol
Rear Speakers 1.75kg
Rear Seatbelts 4.4kg
Rear wiper motor and blade 2.3kg
Rear seat brackets 7.6kg
various bolts 1.5kg
Parcel shelf 4.4kg
N/r boot panel 4.6kg
O/r boot panel 4.2kg
Bootlid trim 3kg
center seat belt 0.7kg
Rear seat backs 17kg
rear door trims 8kg
rear seat bases 7kg
Front sound deadening 10kg
rear sound deadening 6.2kg
Lower boot trim 1kg
air con compressor 5kg
Air con rad 4kg
Air con pipes 1.5kg
parking sensor control unit and wiring 1kg
Spare wheel out 23kg
tool kit. 5.4kg
Fog lights 3kg
Boot floor cover 6kg
Tool kit holder 2.4kg
Some more boot trims 1.2kg
Rear speaker brackets 0.5kg
Center armrest/glovebox 3.7kg
Smaller Battery 2kg
Back looks like this
Heh! I weighed my spare wheel today and it was only 16.6 Kg!
But it does all add up. I wouldn't have thought trim would weigh anything like as much as it does.
It must be a bit buzzy in there now. I was co-driving a fully stripped MItsubishi Mirage Cyborg-R last year, and it was NOT a pleassant place to be for long periods!
That should go like a rocket. You doing anything to get more power out of it, or looking for lighter alloys?
It's not that bad inside to be honest still have all the dash insulation, and around the transmission tunnel still has insulation and the thin carpet is still in, weighted in at 1112kg on weightbridge with half tank of juice, still on standard exhaust/intake for the minute there going to be the only power mods, want to keep it reliable,
Oh and keeping standard alloys for the min as I like how they look, just getting them powdercoated as we speak :)
Bit of rust prevention today, all calipers painted, rear beam/arb, fuel tank straps and under sills hammerited, removed front bumper, changed headlight bulbs to osram night breakers I had laying around, led side lights and changed indicator bulbs as they were showing a little white, fitted quick release bumper straps too, some pics
Well there on :) look great I think goes really well with the colour of the car, lots of pics
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
