Electric Windows Kit
breezer
How easy is it to fit a 2door electric window kit to a yaris?
i was just thinking about it since i can get inside the door panel etc. Im sure i could do all the electrics and the switches bit, but how does it actually connect to the window?
dunno
but wiring it to the alarm took me a while
/me presses the arm button on the remote
the doors lock
the windows go up
I just build from manual to electric windows.
All you need is the door panels and the window engines.
I got 2 engines but they didn't fit because they where japanese an i got a french build yaris.
So i had to order french window engines!!!
The other problem is conecting the wires, your local dealer should have a scedule of that.
It took about 3 hours to fix it all.
If you got a japanese build yaris and you still need the engines for the windows I 've a pair for sale.
They are tested and in very good condition.
brand is "denso" if you need french than you need the valeo stuff.
price for the japanese is € 100 incl shippment to the uk.
Engines are fixed on a lever!
Bye Rutger
