Transmission Fluid Change
capb
Can anyone describe or show me which are the drain and filling plugs on the transmission of a 2.2 ADT FTV 2006 Avensis diesel?
higher one normally is the refill lower is the the drain. I would loosen refill one first just incase you drain the oil and you cannot get refill one to loosen.
this videos may help
