Power Out On Previa
trishamw032670
My previa doest have tail lights, brake lights, heating, fan, power window, dome lighting, dash lighting, radio is kapput, a/c is out . I checked the fuses and they are all fine changed over relays. Any suggestion and solutions are appreciated.
you need a light bulb connected to two wires. One should have a "croc-clip" on the free end, the other should have a probe. The probe needs to be slim-ish because you are going to remove a main fuse, clip the croc-clip onto an earth (the engine?) and put the probe into each side of the fuse-holder in turn. If the bulb glows, you got power. If it don't, you don't. The advantage of a test light over a meter is that it draws current, just like the thing you would like to work. Oh, the other thing is bulbs are cheap.
