Turn Signal/hazards Faulty St202 Celica
Sniper_dude
Sitting in a parking lot the other day.. decided to put my turn signals on and nothing.. left and right do not work. tried to use my hazards and they dont work either..
I have an alarm and when i unlock or lock all the signal lights come on so i know the light its self works..
I have looked in all the places for a fuse or a relay can cannot find anything. Im at a lost end..
looked in the fuse box under the drivers kick panel.. all fuses good. Looked in the engine fuse box.. all fuses good.
Is there a relay and or flasher unit hidden away? is there another relay or fuse box i cannot find??
Help would be amazing!!??
Andrew
Hi, Andrew & welcome to T.O.C.
Assume you have a Gen 6, as ST202 and 2007 is conflicting info.
Woops sorry its supposed to be a 1997.
I have been told that the flasher or relay is in the hazard switch?? is this info correct?
Replace the switch and should fix the problem?
