Engine Rattling Then Cutting Out Told Air Con To Blame
alanmg
My granddaughter has been having a problem with her yaris after running it for a while the 'engine'
rattles then cuts out if she leaves it for a while it starts & runs ok till the next time the cycle starts again.
No fault codes coming up & she got a local garage to test it & look it over.They have told her that the problem is the aircon pump paddle is broken & this is causing all the problems.
They are quoting her around £700 to do the job.
Anyone had this problem,is it likely to be the aircon that is causing the problem & if so can the aircon be blanked off so it does not cause the problem
Any advice most welcome.
Alan
You can get a shorter belt and bypass the air-con compressor.
The following link shows the belts with and without for all engines:
http://www.japan-parts.eu/toyota/eu/2007/yaris-frp/nlp90r-chggxw/2_116520_013_316W/tool-engine-fuel/1605_v-belt
Just a matter of getting the correct length.
I checked on Euro Car parts and they use ContiTech showing various lengths, starting with 6PK923 as the shortest.
http://www.eurocarparts.com/ecp/b/contitech/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt
Be careful as the length may not be correct. I had to replace the belts on my Avensis and one was incorrect to what was on the Euro Car Part catalogue. Get string to measure the length bypassing the air-con unit. The other belt is 6PK970 and the ContiTech catalogue say this is for your engine and year. Both are for non-AC.
http://aam-europe.contitech.de/pages/downloads/docs/Zuordnungsliste-Riemen-Kits--Pkw-Transporter_uv.pdf
Page 676 Yaris 1ND-TV 2005-2008.
Does it idle unevenly as well, even a little?
If so, might also be worth checking the EGR and throttle body in case they are sooted up.
Seems a bit weird the aircon could cause the engine to stall tho'... Is it a normal aircon system that you can switch off or is it a climate control system?
Thanks guys ,I am going over on sunday to have a look at it , hopefully will sort it out.
