Need Help Too!
cguyfish
I've got a 94 with 1.8.. I recently washed(too much u big dummy)under hood to clean for new valve cover gasket. After installing i went to crank.It started missing(of coubik)then it died. After that Had no fire. Started checking at plugs(no fire). Then Went to
distributor(wires ok)Pulled the cap and checked with light at + side of coil(solid light there except for a little starter surge while wife turned engine over...Then checked - side of coil( got blinking light while she turned over motor..Also put cap bac on and pull 2 wire plug apart(thats on top of distributor and performed this. http://www.howstuffinmycarworks.com/Ignition_coil.html .. When I got to the part about probing the second terminal I got no light
distributor(wires ok)Pulled the cap and checked with light at + side of coil(solid light there except for a little starter surge while wife turned engine over...Then checked - side of coil( got blinking light while she turned over motor..Also put cap bac on and pull 2 wire plug apart(thats on top of distributor and performed this. http://www.howstuffinmycarworks.com/Ignition_coil.html .. When I got to the part about probing the second terminal I got no light. Hope I explained my problem
