Need Help With A Smashed Yaris
LTmaverick
hi, im from portugal and my english is not very good. i buyed a smashed yaris for repair but the engine mount in the passenger side(right side) is broken, well, the mount is ok, in fact its broken on engine..what do i need to repair it? will i have to buy a new engine?
If the cast engine casing mount has snapped then yes it sounds like you'll need a new engine, or new casing - and a new / replacement engine will be easier than replacing just the casing to be honest.
the holes for the bolts in the engine mount are broken...
anyone?
You've already been advised and haven't provided pictures of the actual damage, unless you can do that I'm not sure what else you expect someone to be able to say?
Looking at the images you provided (I know they are not your actual engine), The casting of the timing gear cover has broken off.
Here is the link to the part:-
http://www.japan-parts.eu/toyota/eu/2008/yaris-frp/ksp90l-cgmrkw/2_116520_025_316W/tool-engine-fuel/1106_timing-gear-cover-rear-end-plate
If you can source the part and a mechanic does the work well and cheaply, compared to sourcing a complete engine. The work to replace the engine must far exceed getting the part replaced.
Is the rest of the engine okay. What about the car. Is it a right off?
Jonathan did advise you to post some photos of the damage to the engine and car. It removes a lot of guess work.
the rest of the engine is ok..i already had checked that link but didnt find where to buy :( do you know where i can buy? i would prefer a used one but new is ok
