Oil Filter Removal Tool
mastereagle
hi there
i need a oil filter removal tool for 08 2.0 avensis 4d4.
i have seen a few around online but they all have diferent sizes, i would be very gratefull if anyone can help.
many thanks
regards
hi raistlin
thx for reply, but its not of of these, its a tool like a socket and unscrews the top and then a paper filter is inserted into the actual filter.
http://www.ebay.co.uk/itm/BGS-Tools-End-Cap-Oil-Filter-Wrench-100mm-x-P15-1039-100-15-/231307616649?pt=LH_DefaultDomain_3&hash=item35db022189
example above for the 1cd-ftv engine, you need to measure diameter and then the flutes (flats) put that into info eBay and you should find the one you need
Um, I'm just wondering if anyone has had any luck using the old webbing strap and socket attachment type tool? You know the type, the old school ones that used to work on cartridge filters.
example above for the 1cd-ftv engine, you need to measure diameter and then the flutes (flats) put that into info ebay and you should find the one you need
thank you
http://www.toyotaownersclub.com/forums/topic/167488-oil-filter-removal-tool/
The 6th post shows my selection of oil filter tools.
The one you mentioned worked well for tight spaces, using an extension for reach. It was a bit awkward to use. The filter had to be clean so the band could grip. The tool next to it is far better. Got that from Machine Mart.
the one you showed is ok, but for my 1cd engine its a bit awkward as filter is on its side and is tight for space.
I have just bought one of these
http://www.ebay.co.uk/itm/NEW-12-OIL-FILTER-ADJUSTABLE-WRENCH-PLIERS-HAND-REMOVAL-PLIER-TOOL-/381034510425?pt=LH_DefaultDomain_3&hash=item58b76d3859
not tested it yet but it should be able to help with the fuel filter I am currently using water pump pliers on it.
have you tried it yet on the oil filter???
is so let me know how easy or hard it is to change the filter cap with it.
many thanks
anyway, does anyone know the actual size in mm of this oil filter cap???
is it same with all avensis or changes as the years go by?
many thanks
hello all.
finally i managed to change the oil filter on my 2008 2.0 4d4 avensis.
i used one of these and worked a treat, so in case anyone will need it. its a cap 65mm/67mm 14f(flutes)
and is something like this
http://www.ebay.co.uk/itm/Laser-4990-Oil-Filter-Tool-Toyota-Yaris-65-67mm-x-14-Flutes-/320774780671?pt=LH_DefaultDomain_3&hash=item4aafaab6ff
hope that helps.
regards
