Engine Fumes
lineman#1
Hi everyone
I have a 2011 rav 2.2 diesel. Firstly I have a tapping noise that sounds like it is coming from the back of the engine around the injector pump area. The noise is quite loud at idle and when under load. I thought it may have just been diesel rattle but now not so sure. Also while looking for this noise I happened to remove the oil filler cap with the engine running and it seems to fume a lot from the top of the engine, Is this normal? The engine has only done about 35000 miles and has always been serviced.
Many thanks to you all
Take care
Lineman
