i have a problem with a 2 year old aygo. no dipped headlights on bothsides. i have checked the fuses and they are ok. side lights are working and ok as is full beam. could this be a problem with a relay.
thanks again.
Have you checked the bulbs?
bulbs seem to be ok
thanks for your quick reply
Can you elaborate on what you mean by seem to be ok?
hi , yes i have taken them out and put a meter on them, it shows a circuit so i think they are ok. the full beam element and main beam are all in the same bulb so the gas must be ok. thanks again
The most likely cause is two blown bulbs, just try a new one first before looking elsewhere for problems
I had this last week and it was a blown bulb, replaced them with Phillip's Blue bulbs which are 90% brighter and all is now good.
Another possible problem is the indicator/light switch could be playing up, can you wiggle the switch between dip and main beam and see if the bulbs light up ?
